RCU Forums - View Single Post - E-FLIGHT BLADE CP
Old 09-04-2007 | 09:38 AM
  #4758
FMB42
Default RE: E-FLIGHT BLADE CP
NOW the heli won't even lift off. I've got way more negative than positive collective pitch.
Double check the expanded view in the manual just in case something is out of place or reversed. Might even be that you have the swashplate ball links installed on the 90 deg balls rather then the 120 deg balls. I'm not sure if this is possible but thought that I'd mention it anyway.
