RCU Forums - View Single Post - Best way to repair wire landing gear
Old 09-04-2007 | 11:16 AM
hogflyer's Avatar
hogflyer
Default RE: Best way to repair wire landing gear
Depending on what is damaged, there are two fixes. The first is to drill out the hole in the landing gear block oversize and insert a dowl, then redrill. If this doesn't do the trick, then you'll have to cut into the wing to do a proper repair and re-secure the block assembly. Give the dowl a show first as it's the easiest.
Hogflyer
