8103 program mixing problems
I wish to set up the programing in my 8103A transmitter so that the following is possible.
When the elevators are actived up, both ailerons deflect down, and vice versa, (Flaps) in order to achieve tighter loops.
I would like to be able to switch this capability on or off via a switch, and also be able to select how much deflection of the flaps I want.
I have each aileron operated by a separate servo. One pluged into the aileron location in the receiver, and the other into Aux 3 in the receiver.
Both elevators operate from one servo.
Thanking you in advance,
Mooose.
