Weston UK Magnum questions
Well, basically, any fuel of 10% nitro and 18% oil should work then right? Prosynth just doesn't exist in Canada, and with dangerous goods, bringing it over from the UK, or even across from the US, even up from another Canadian city is ridiculously expensive.
I've always run Powermaster, I've run it in YS, Nelson, OS ducted Fans, everything I've owned without a problem. I can't imagine why warranty would void by not using a particular BRAND of fuel.
From what Alan told me at weston UK, the connecting rod failure was a result of the bushing being pressed in incorrectly. Mine failed in the first 40 seconds of running, even if I'd used no oil, the amount of damage the rod sustained would not have been fuel related.
