RCU Forums - View Single Post - Project AXE CP Main Gear Transplant
Old 09-05-2007 | 05:27 AM
Heliko's Avatar
Heliko
Default RE: Project AXE CP Main Gear Transplant
I put on an MX400 main gear a while back and it has worked pretty well with the Axe's mainshaft. I did have to do a couple of things though to make it work.
I had to press out and flip the one-way bearing so I could center the gear without cutting the frame.
I also had to flip the mainshaft and drill a new hole for the rotorhead bolt. The reason I did this was so the bearing didn't have to ride on the flat spot cut for the Axe's stock main gear.
ID:	756921   Click image for larger version
