RCU Forums - View Single Post - FUel tank mod for Revo - can anyone explain why?
Old 09-05-2007 | 07:36 AM
hotrodf1
Default RE: FUel tank mod for Revo - can anyone explain why?
The other problem would be that the fuel pressure needs to change as the RPMs change, so the pump would have to be pretty flexible. I was thinking about a renewable pressure source, such as a CO2 cannister or something that you could bleed pressure from and use as your "fuel pump". Not sure that would be real practicle though, but maybe. . . . .
So you're saying that a tank with more surface area on the bottom will exhibit less of the lean tank problem? Like a long narrow tank, that 's maybe not as tall?
