RE: Powermax Trigger Valve
Thanks. Looks like I'll have to cut off the bottom threads to the rubber gasket and then add a little brass tube into the bottom of the valve to get it to go into the can. Can you take a close up of the very bottom that has the brass tube? Thanks again.
