RCU Forums - View Single Post - On board cammera.
Old 09-05-2007 | 11:44 AM
opjose's Avatar
opjose
Default RE: On board cammera.
ORIGINAL: VFR_RC
Look on ebay for digital 2.4GHz recorders. They capture the image from your camera and record it to a Secure Digital card.
I ended up purchasing a cheap $99.00 Aiptek Digital Video Camera that records 70 minutes of 720p video to an SD card.
See: http://www.aiptek.com/
I mounted the 6 oz camera ( weight with batteries ) just in front of the wing on my .60 big stick, using a small light tripod head.
I had thought about putting in another servo to rotate the camera in flight, but I didn't find this was needed.
I disliked the "tearing" caused by shooting forward through the prop, so I later simply mounted the camera on top of an extension tube made for regular cameras, to move it above the prop.
I've flown this setup about six times thus far w/o problems.
The Aiptek camera's only problem is that the camera "door" must remain open for the camera to be powered. It tends to close in flight due to air pressure.
I ended up disabling the door switch to solve this problem.
A cheap solution which works very well, and I still use that little camera for other purposes too.
