RCU Forums - View Single Post - Bubby Box cables
Old 09-05-2007 | 01:49 PM
CGRetired's Avatar
CGRetired
Default RE: Bubby Box cables
Well, then if that's the case, then the only way to see if it works is to try it. My Realflight 3.5 uses the USB Interlinkl. I do recall the older version had a different setup with the cable and if so, that may... MAY work, but don't be surprized if it does not.
Buddy boxes are not that expensive, you know.
http://www2.towerhobbies.com/cgi-bin...&I=LXLV14&P=ML
Futaba for $44.99 from Tower.
