RCU Forums - View Single Post - Schulze Chamaleon
Old 09-05-2007 | 05:33 PM
Miguel Santana's Avatar
Miguel Santana
Default RE: Schulze Chamaleon
ORIGINAL: Spartan Missile
I replaced 1st & 3rd fets from top left hand side with the nearest equivalent i had at work IRFZ44
T0220 package
Pin out from left to right gate, drain, source.
Low RDSon, something like 0.025ohms.
Anything similar will do.
Be careful not to damage thermal interface strip when replacing the fets, you will end up shorting the drain pins
Please confirm the exact reference of the part.....IRTZ44? OR IRTZ44 T0220?
There is big chance that I can get it locally, but need to be sure what to ask
The other possibility is to order the capacitors to ALL ELECTRONICS....
Thanks in advance for your support,
MS
