RE: Thrust angles??
Thrust lines are thrust lines whether you are using glow, eklectric or a steam engine. Glow engines usually have more rpm than electric but not much, also the props cause different thrust vectors to be more of less effective. Suggest you mount the electric using 2 degrees down and 2 degrees right if it is in tractor mode. Norm
have fun
