RCU Forums - View Single Post - problems with my yokomo
Old 09-06-2007 | 10:56 AM
redeyes's Avatar
redeyes
Default RE: problems with my yokomo
hey walmartsec...
Did you mention you only put the ABS on the rear?
Maybe try and tighten the shocks in the rear, then adjust the camber a little...
and, your sig says springs.. which ones? I personally like mine soft, a little tighter up front, a combo like yellow/white spring and 30-40 shock oil.
and hyperhks, do you have all the bearings installed, everything is clean and spins freely? The front wheels should spin clean and quiet one way.
Check your bearings/bushings at the end of your shaft, and if thats all good, the difference your feeling, may just be the one-way. Drifting with a one way does feel really different.
