RCU Forums - View Single Post - Nexstar
Thread: Nexstar
Old 09-06-2007 | 11:43 AM
hogflyer's Avatar
hogflyer
Default RE: Nexstar
You can also leave off the flaps and wing droops - I think the plane flies much better with out them. If you have the radio capability, run dual aileron servo's - the plane is set up for them and has the draw strings already built into the wings along with the pockets for the aileron servo's. This will allow better control over the ailerons and the addition of full span flapperons in the future when you have completely mastered the NextStar.
Very important - EPOXY the empenage on with 30 minute epoxy and don't rely on those plastic nuts they supply as they can strip out quite easily. Use the plastic nuts to help tighten down the empenage while the epoxy cures.
Hogflyer
