Ok guys I have the aero works extra 300s from ak models. Running a os 91 max on it. Pull pull on the rudder, 1 pushrod with two threaded steel rods running to the elevator. I am using the JR XP6102 radio that I fly my helis with to. The Ailerons have one futaba s3004 servo a piece. It is a joined one piece wing.
I just cannot get this plane to roll fast at all. Very slow roll rate. I mean snal slow. The throws are just about maxed to. I am baffled as to why it is slow. Below is what another member said to me and I was hoping someone could elaborate or explain to me what I need to do to get her to rock and roll
"fellers
Sounds like you need to do some role coupling to get your roles to work better. It has to do with the upward moving wing has more or less lift than the downward moving wing. On a Futaba computer radio. I think I use the flaperon funtion +or- 2to5%. Not sure if that is correct. but look aroud you should find some instructions to help you with your situation"
