RCU Forums - View Single Post - Extra 300S Can't get it to roll fast, help plz
Old 09-06-2007 | 10:54 PM
fellers's Avatar
fellers
Default RE: Extra 300S Can't get it to roll fast, help plz
ORIGINAL: bubbagates
sounds like blowback.Are you sure the servos are strong enough and what size control rods are you using. If they are too small they could be bending under load
I'm not sure if the servos are good enough or not. They are futaba s3004 -Torque 44 oz/in. at 4.8v.
Can I run a 6 volt pack on a plane?
Using a jr 700ppm reciever. On a heli I can't use 6v because of gyros and tail servo won't allow more than 5 before you deep fry them.
The rods are the stock rods with it.
The plane has narrow ailerons, about an inch and a half if that.
The rod is only about 5 inches to. Plastic clevises. Will be changed to metal before next flight.
