RE: Engine tuning question
In addition check the the backplate is still tight and check the bleeder hole on the front of the carb is clear.
You can do this by opening the mid range screw several turns an then pushing a thin pin all the way through. Then close the screw back in untill you can feel it on the sloppy fit pin.
John
