RE: Centering trim tab
the trim tab for the forward and reverse works on the S&S versions. Would be nice though if when in the stopped position on the main stick the trim tab was also in the center position is all. I was wondering if I was to solder a small trim pot in series to the one lead and center the trim lever then adjust the trim pot till the motors stop this might give full use of the trim lever
