RE: Focus Sport 110 YS Powered
Troy,
I will be building along with you. I also will be using the new YS-110 (slightly broken-in).
Do you have a set of recommended build items to buy from Central (Hyde mount, FAI spinner, etc)? I already have the electronics and servos (will be putting 9451's in the wing and rudder. Not sure what I'm going to use for the elevator as the 9451's are a little heavy for the tail (2x 2.2oz). I would like to get the engine mounted and the tail assembled prior to making the elevator servo decision (it might just need the weight back there).
-Jeff
