Monokote application
Hi ibekdog,yes,unless it's Monokote that's stuck to itself.I turn the iron up to 400 degrees and that takes care of most all wrinkles,the iron will do the same.If you stay on an area to long with high heat you may burn a small hole in the covering,I would rather add a patch or two than have a plane that is nicknamed "the prune."
