RCU Forums - View Single Post - Extra 300S Can't get it to roll fast, help plz
Old 09-07-2007 | 12:18 PM
ram3500-RCU's Avatar
ram3500-RCU
My Feedback: (221)
Default RE: Extra 300S Can't get it to roll fast, help plz
ORIGINAL: fellers
ORIGINAL: ram3500-RCU
Did you seal the gap on the ailerons? If not, seal them. Your ailerons will be more effective.
ok, i have not.
the roll rate is about the exact same as the p-51 on realflight g3.5 with retracts.
How do I seal them. Thin strip of clear packing tape on top only?
Clear packing tape will work. I use clear monocote, but that is me. Sealing the gap is the easiest thing to do for a start. I would try it first and see how much it improves. Only takes a few minutes. Be sure to clean the area well with alcohal before sealing. I would say that the % of improved effectiveness would depend on the size of the gap your sealing.
Be sure also to move the control to maximum before you apply the sealing material so as not to create any binding and allow full travel.
