RE: Extra 300S Can't get it to roll fast, help plz
Maybe try this; Make sure the aileron servo travel is maximized in your transmitter while using the shortest servo arm possible that will give you full throw at the aileron.
I have seen this problem occur when servo arms are to long and servo travel is decreased electronically in the transmitter to give desired throws. Hope this helps. Good luck.
