RCU Forums - View Single Post - Engine tuning versus pipe length
Old 09-07-2007 | 05:32 PM
moparbarn
Default RE: Engine tuning versus pipe length
ORIGINAL: Hesco Racing
Before saying go shorter or longer on the tune length it must be understood what is actually happening when you change this.
if it MUST be understood, then why didn't you explain it? pressure waves, convergent cones, divergent cones........ who cares, unless you are building pipes or are a tech freak. as long as you know what longer and shorter cause, then it's all good. the info given here is good, and all you REALLY need to tune a pipe. you may have to try a few different pipes to find what works for your setup, driving style, and boat. two "identical" boat/motor combos may not like the same pipe, in the hands of different drivers. just another excuse to go burn more nitro!
