ORIGINAL: Orion1024
Definitely sounds like it could be a vibration issue. Make sure the main and tail shafts aren't bent, the main and tail blades track properly and are balanced, etc. There's other possible causes, as well, like a damaged servo or binding somewhere. That's always half the battle of a rebuild...getting everything adjusted and working as well as it did before.
thanks for getting back to me, I really cant thank you guys enough.
Your tellin me, (about the setup) I'm about 1 battery cycle away from trashing this whole heli hobby, its really cuting into my airplane flying time.
Its a vibration issue. with out the rotor blades the heli is smoth as silk all the way up to full throttle. Once I put install the blades the problems begin.
I just cant get them balanced, and then one blade is heavier that the other so on run up the heli looks like an out of balance washing machine.
I was into this really heavy 20 years ago, not much has changed for the better In my eyes. The gyro's are better, and everything else is plastic instead of metal.
I found a bag of plastic control rod ends from my GMP King Cobra. They lock onto the ball and NO and I mean NO drag on the metal ball. The rod ends that came with my MX's are POS I cant belive what a POS mold they came from. The bind on every ball on the heli, you have to spend hours reworking them or trash them and use a different system.
check out these control rods
JUST VENTING[X(]
I loaded up the U-Can_Do 46 into the truck for the weekend, I'm going to vent off some frustraions by putting the plane through a few routines.
