EZ Zero Decals
Hi Scott:
It's been a few years, so I went and looked at mine. One of the decals, no 4 I believe (shorter one), I put on the trailing edge of the flap next to the fuse (like a "no step" warning). The other I did not use, because my documentation and the instructions do not have a place for it. Not sure if this was correct.
Your gonna love this plane. It is still one of my favorites to fly. I have been flying it for a couple years. No bad habits, and looks good in the air. Most of the people at the field are amazed at how stable and easy it is to fly. Mildly aerobatic also.
After two years and hundreds of flights, I had to reinforce the stab where the joiner wire is glued in, mine was getting a lot of play. The balsa is weak and fuel got to it also. Was an easy fix. Keep an eye on it.
Good luck!
Cal
