RE: New to Lipos
Cycleeric,
Ask around in the Car forums.....someone there might be running a similar set-up and would be able to tell you what will work and what won't. Really with out knowing how many amps that set-up will pull with the current gearing I can't safely tell you which pack to go with. I don't want you to ruin your equipment or a Li-Po pack.
Jason
