Hydromite setup question!
Hello all,
I'm in the process of building a hydromite, and I'm trying to use existing equipment from my airplanes to power it. My question is, I am using a Typhoon 2w-20 from an EDF plane (3350Kv, 28mm can), what would be a good starting point for prop/battery? I'm planning on using 3s, either 1320 or 2100, but where should I start with props? Also, what would my run times be (approx) with either the 1320 or 2100? I appreciate any help you can give!
Thanks in advance!
