RCU Forums - View Single Post - Question on using a Dave Brown spinner
Old 09-08-2007 | 02:40 PM
EF
Default Question on using a Dave Brown spinner
When using a 4.5" spinner on an OS 1.20, the spinner's adapter doesn't have enough threads to go on if retaining the original 2 nuts for the prop.
What is the best solution? to use only one prop nut and risk a loose prop if the engine backfires? or will the spinner adapter fill the role of the second/front nut?
