RCU Forums - View Single Post - Recommendation for two elevator servos
Old 09-08-2007 | 04:40 PM
mwick
Default RE: Recommendation for two elevator servos
Yes, cut the side mounts off. Be careful, don't try to snap them off with pliers, you will break the case. I use a small dremel wheel and slowly cut them off, being careful not to hit the wires. I believe the instructions that came with the servo also talk about removing the side mounts.
