RE: Basic building tools
Skip the razor saw set and buy a Zona 500 razor saw. Its the best out thier and all you will need. Skip the Sealing tool, not needed in most instances. You will need some 1' sanding bars and a long steel straight edge. I would buy some 30 min expoxy and skip the 5 min stuff for now. Don't buy more then 1 oz bottles of CA or you will be throwing it away. Sand paper, 36# for carving, 80# rough sanding, 150#,220#,320# for finish sanding. T pins, rubber bands, alot of masking tape: automotive grade. Alot ofNo 11 knife blades, get the Xacto brand, their much better blades. Tape measure and good 12" ruler for exact measuring. Flat building table and I mean flat, a ceiling tile, wax paper, Dremel tool with cut off wheels, drill and bits, Small screw driver set, hex drive set and on and on. good luck and have fun. Canopy glue.
