RCU Forums - View Single Post - Loctite on Propnut?
Old 09-08-2007 | 08:44 PM
RCKen's Avatar
RCKen
RCU Forum Manager/Admin
My Feedback: (9)
Default RE: Loctite on Propnut?
No, you should not put locktite on the prop nut. I know you said you have it as tight as you can get it, but it's still not tight enough. Use a box end wrench to tighten the prop nut with. Don't worry about damaging it as the nut and shaft are both steel. Also use a glove on the hand you are holding the prop with so you don't cut yourself.
Ken
