RCU Forums - View Single Post - Loctite on Propnut?
Old 09-08-2007 | 09:35 PM
bruce88123
Default RE: Loctite on Propnut?
ORIGINAL: B.L.E.
Richen up the mixture if you are using a 4-stroke glow engine. Loctite comes in three strength grades. Blue, Red, and Green. You want to use the Blue Loctite.
No - you DON"T want to use Loctite PERIOD, on a propshaft.
What engine do you have?
If the nut keeps coming loose, there is something else wrong. Find the problem and fix it, don't cover it up and create MORE problems.
