RE: HERE INFOS ABOUT OS 75 AX
I'm one of the suckers who just purchased the .75AX. Plan to bench run it Sunday. Will use T-F power point 13x8 cut down to 10x8 for the break in prop and Omega w/ 15% nitro.
Based on a little experience and what I've been reading, you all are expecting this 2 stroker to swing to much prop, OS included.
This is just a punched out 61fx, a little more bore and stroke in the same weight package, which is what I want. I think 14x6 is going to be the high end of the prop range.
I'll let you know how things work out.
SE
