ORIGINAL: bruce88123
ORIGINAL: B.L.E.
Richen up the mixture if you are using a 4-stroke glow engine. Loctite comes in three strength grades. Blue, Red, and Green. You want to use the Blue Loctite.
No - you
DON"T want to use Loctite
PERIOD, on a propshaft.
What engine do you have?
If the nut keeps coming loose, there is something else wrong. Find the problem and fix it, don't cover it up and create MORE problems.
EASY BOYS this is supposed to be fun
HE is right but he didn't "splain" himself Lucy. SOMETHING has to give so let it be the nut. beats the heck out of rebuilding motors. and if it is popping or backfiring fix that ASAP. Also are you useing the washer that is suposed to be in front of the prop? It is possible that you are bottoming out the propshaft in the hub. By the Way I like those hubs too.
