RE: Club FOX!
I have the fox .15 with c/l venturi. Fox instructions state this engine MUST be run on fuel containing 20% castor for lube. I have been running duke's in mine without any problems. The piston is iron running in a steel sleeve, so lots of castor is a must. I don't think straight omega is going to cut it here. Probably explains why your engine is getting so hot.
