ORIGINAL: Ed_Moorman
Here's the twin tractor and the seaplane.
Designing a new plane takes a lot of engneering and a lot of "cut and try" type effort. I believe you must resign yourself to building a minimum of two planes, probably three would be better. This is especially true of the non-conventional designs, like canards and flying wings.
Take our flying boat canard, the Duck. Carl "Flaps" Laffert is the designer (with my input). Right now, it flies, but needs several changes. It took a lot of weight to get it to balance. The engine needs to be moved forward to alleviate this. Overall, it is heavy and has a fairly small wing so a larger wing is needed to lower the wing loading. In addition, the engine mounted on the fin with its high thrust line, we think is giving us a pitch down moment so I am compensating with up control trim. Then when I throttle back for landing, it tends to raise the nose. I can put in a landing program to have some down control switched in, but I'd rather have some up thrust.
As long as his designs fly, Flaps doesn't want to do too many changes. Generally, he wants to see them fly for 3 or 4 weekends and he is off to something else. I would like to see a new plane, slightly longer, with the engine pylon in the fuselage forward of the wing with more up thrust. Plus I want a much larger wing.
Thanx for the pix. I have had a thing for canards since spending some time in Rutan's place in Mohave several years back. I lived in So. Cal. when he was the hottest thing since pancakes. Wanted to build a Veri-ez but never had enough dough. Love to fly, but RC's are a good substitue for us poor folk.
I had thought a lot about a sea going canard (which, of course, goes with the name) My avitar come up in Russian language (actually Cirilic) says DUCK phonetically. That's the name I gave this plane when I came to the forum. I called it Wasp before that because it looked like it could sting. (sorry, rambeling)
My first canard design was with the nacels next to the fuse, but having them forward of the wings would have to be quite a long fuse, it seems. Of course if you make the canard large enough, you can adjust accordingly.
I am building a model "B.2" for a friend of mine after this one and then an A-10 foamy ,maybe versa visa. I say model of "B-2", because after that he an I are building an "experimental" B.2 (10% size B-2) Maybe I'll get to fly that one. He is a aeronautical brain as his hobby and has his own Architech business.
Thanx again and I want to go back and look at your pix more.
Ionikios
