I'm running Morgan's 15% Omega.
My experiance is that it may not run well on this fuel till its broken in. Otherwise the excess friction will heat up the cylinder causing the seal between the piston and cylinder to be broken, this allows blowby which further heats the engine. It will act exactly like it is running too lean.
