RCU Forums - View Single Post - evolution .46 still cutting out
Old 09-09-2007 | 10:33 PM
  #53
opjose's Avatar
opjose
Default RE: evolution .46 still cutting out
I recently had two different engines with similiar problems... I was trying to help someone else out at the field.
In one case the person had the clunk just shy of contacting the back of the tank. This was well and good superficially, but when at the field it turned out that because of the angle of the plane, the clunk was actually contacting the back curved wall of the tank.
When this happened, you would get exactly as what you describe!
Why?
Well the clunk has a cutout that permits fuel to pull from the side, even though it was up against the tank wall.
However when the throttle was run fully up, the contanct with the back of the tank restricted the flow to the point that the engine cut out ONLY at high throttle... and it was fine all other times.
This drove me nuts looking for other issues.
The second case was similiar, ultimatly a fuel flow problem. One of the fuel lines was being pinched off INSIDE the plane, restricting flow at the higher rates.
If the engine passes the 3/4 throttle pinch test and you've eliminated carb leaks, etc. ( assuming you do not have too HOT of a plug on it as well... ) look "outside" the engine for the cause.
At worst, try hooking it up to a new tank that is outside the plane, and see if it runs that way.
One last note, are you SURE that the needles are not "walking" as you advance and retard the throttle?
