ORIGINAL: sidv13
anyone know which turn fins I should get for my SW26 and amybe trim tabs if you think they are needed I was lookin on OSE but I dont know which ones would work the best. also what is a good prop to upgrade to with the stock setup that wont kill the motor or ESC.
If you want them to look pretty and you don't mind spending money then get these. You don't really need trim tabs with the SW26 because you can adjust the outdrive.
http://www.offshoreelectrics.com/pro...qub7882&cat=67
If you don't want to spend the extra bucks on the pretty blue then get these, they will work just as good.
http://www.offshoreelectrics.com/pro...rod=kyo-94241b
If you want a razor sharp front cutting edge for the least resistance then get these.
http://www.offshoreelectrics.com/pro...d=ose-monofins
Or you could also sharpen the others.
