RE: Pull-Pull Rudder Setup Help
The pull pull wires do not and should not be guitar string tight-it will put too much stress on the servo and related items. Either the rudder is not free enough or the servo is not centering-its not in the wire tension. Just taunt is fine-do some comre checking and let us know what you find-assuming you are using plastic coated cable or kevlar.
