RE: Pull-Pull Rudder Setup Help
you don't want the wires very tight. full scale uses very little tension on the cables and some small airplanes have none and use springs on the rudder pedals to keep the cables tight. it may be your servo does not return to the same center, I have had this problem. or it may be to much friction in the hinges, there should be virtually none.
Charliek
