RE: Extreme composite Pro-Line
The check valve works well but complicates the fueling system. The same valve that doesn't let fuel escape while flying won't let air escape while fueling. Somehow you have to vent the tank to the outside, a tee in the vent line with a plug or similar setup will work.
