RE: Glitch Busting Help
Here's an update:
Today I was going through all of my wiring and found some connections that could have been tighter. I started re-wiring all of my servos with new wire and connectors. The only pigtails I'll need now will be for the ailerons to plug in. But the big news (to me that is) is that when I started to take the smoke pump out the controls went crazy. I rewired the pump with new battery and control leads, and the pump still caused some interference. Needless to say, I'm sure it's the problem. Other than the pump, the setup is pretty close to what I have in the small Edge. I'm going to finish rewiring the rest of the servos and give it a test flight this weekend.
Thanks for all of your help. If the glitch persists, I'll let you know.
Sam
