Insane control throws - how to?
If you run pull-pull to your controls you can set your horns behind the centerline about 3/8 to 1/2 inch and this will increase your overall throw and your torque compared to running the horns on the centerline. But remember as you said the longer the arm and shorter the horn....the more torque you need to make the system work.
