RCU Forums - View Single Post - Old Expy
Thread: Old Expy
Old 03-19-2003 | 07:13 PM
Ghostbear
Default Old Expy
Well, I got the wing on my 4*60 (built upside down) apart, and after ten minutes with a heat gun pulled the shards of the dihedral brace out.
Doesn't look too bad.
Anyway, there is old epoxy on the inside ribs. I tried scraping it off under heat and it worked ok, but how clean does it need to be?
I'm going to insert a new rib-shaped "shim" between the wing halves to correct the dihedral angle and add a new brace before applying the fiberglass tape.
Do I have to get down to bare wood or what?
GB
