ORIGINAL: horace315
use a heat gun,a blow dryer on high heat will work also but not as good and just slowly peel them off dont be in a hurry.
What he said works very well. Just use a much lower setting than you would normally use for affixing covering.
If any adhesive remains try various cover safe solvents on the adhesive...
e.g. first WD-40, then alcohol.
