RCU Forums - View Single Post - Spinner questions
Old 09-11-2007 | 01:20 PM
opjose's Avatar
opjose
Default RE: Spinner questions
You can indeed move the engine forward a bit, which is very easy to do with the included mount.
This barely affects the C.G.
I use the Great Planes spinners on this plane, which require no changes.
You do not need to remove the flywheel, but you can if you want to.
If you've added tail weight to the plane you can typically remove it after removing the flywheel.
