RE: Noob Crawler with WK
well once you lock the front your steering does get worse its that good old push pull thing but you really do need difs locked and as far as a width rule goes it only counts on your tires and wheels you have to run a 2.2 if you run a bigger tire and wheel than a 2.2 than you will have to run in the super class as far as the battery weight if you like the way it runs leave it be
