RE: Servo arm selection question - ?
The longer the servo arm the less force on the control surface. Thrust is the same for any length of servo arm as it is usually labeled in in/ounces so a 1/2 inch arm will have twice the thrust of a 1 inch arm. However you are better off to use as long an arm along with as long a control horn as you can as the slop in any connection will be minimized.
