RCU Forums - View Single Post - Wiring issues with separate ESCs
Old 09-11-2007 | 09:27 PM
AFDrifter
Default Wiring issues with separate ESCs
Well, I took the plunge and went with separate ESC for my Axe. I thought I had everything wired correctly but I'm not getting any power to the Rec'. I have the pos/neg wires from the esc's soldered together to a Deans ultra plug. The Main ECS has the Blue/White wires soldered to bullet connectors and connected to the Main motor, and the three wire plug from the ESC (BEC) is connected to position three on the Rec. The Tail ESC is connected to the Tail motor and to the GY240 which is connected to the Rec'. Maybe someone can check my work. Do I need a power plug to go to position Five on the Rec? Any suggestions would be appreciated
EDIT 1: Yes the BEC fromt he Tail ESC is disabled.
