Aw comeon, Jetmech..
The Nexstar is a fine trainer. Just remove the gizmo's and fly it. I used the wing-tip spoilers and the brakes for a while, but right after I solo'ed, I removed them and flew just fine (after somewhat of a bit of elevator trim).
But, both the Alpha and the Nexstar should do the job just fine.
PS. When did you say your daughter graduates from Cape May?
